Clears the neighbor information for the specified ESRP domain.
| esrpDomain | Specifies the name of an ESRP domain. |
N/A.
If you add a new switch to your ESRP domain, use this command to clear the existing neighbor information for the ESRP domain. After the switch is up, running, and configured as an ESRP-aware or ESRP-enabled device, new neighbor information is learned.
Before using this command, schedule a downtime for your network. Use this command for maintenance purposes only.
The following example clears the existing neighbor information on the ESRP domain esrp1 after adding a new switch to the ESRP domain:
clear esrp esrp1 neighbor
This command was first available in ExtremeXOS 11.0.
